What to use to waterproof mooring cover? >
Old 03-21-2007 | 02:39 PM
Default What to use to waterproof mooring cover?
Some people say thompsons waterseal and the others say the stuff from west marine. What are you guys using??
thanks
djtalon is offline
Old 03-21-2007 | 06:16 PM
I've always used the Starbrite product. Wash the cover every spring, let it dry and water proof it. Never had a problem with it leaking even in pouring rain. Cover is about ten years old. I was also wondering about the Thompsons. The Starbrite is over $20.00 a gallon. Is the Thompsons less expensive ?
Dave
David Stotz is offline
Old 03-21-2007 | 08:11 PM
Ted G's Avatar
Sunbrella recommends 303 protectant after a good cleaning with mild soap.
www.cbpba.com
Ted G is offline
Old 03-22-2007 | 11:55 AM
Our shop has always used Thompsons on the soft tops for our cars. ( Benz dealer )
benztech is offline
Old 03-22-2007 | 12:36 PM
KNOT-RIGHT's Avatar
My interior guy told me about the thompsons water seal
I laughed. But I tried it . Goes on milky white.
When it dries you cannot even tell you did it.
It worked awsome! I could not beleave the results.
KNOT-RIGHT is offline
Old 03-22-2007 | 02:47 PM
sleeper_dave's Avatar
Do you just spray the thompsons on?
I've heard of using it before, and it sounds promising. Hopefully a bit cheaper and more effective than the stuff at west marine.
sleeper_dave is offline
Old 03-22-2007 | 02:56 PM
KNOT-RIGHT's Avatar
paint brush.
You wont beleave the results
Old 03-22-2007 | 04:58 PM
waterbum's Avatar
I put a gallon of Thompsons in a deck sprayer (the kind you pump up )and let it rip. Works great. I have a canvas cover and the water beads up and runs off like it's covered with a plastic film. I used to buy 5 or 6 spray cans of the silicone spray. Most of that blew off into the wind while I was spraying. Thompsons is the only way to go in my opinion. I tried the brush method, but it seemed to put on a really heavy (wet coat) and took a long long time. Spraying takes about 10 minutes including setup and cleanup. Leaves more time for standing back, admiring your work and having a beer.
waterbum is offline
Old 03-22-2007 | 05:44 PM
I used the Thompson's on a cover back in the late 90's and it worked great at repelling water but after about a year the cover became very stiff and unflexible compared to before using the Thompsons.
Ryan00TJ is offline
gerritm
Fountain
9
07-30-2008 08:59 PM
fast357
06-06-2008 05:10 PM
sandcraft
2
03-18-2008 10:07 AM
BY U BOY
Scarab
2
07-06-2006 12:45 PM
Steve_H
06-01-2002 07:37 PM
