Holley fuel pump mounted on raw water pump >
Old 03-26-2007 | 06:10 AM
Default Holley fuel pump mounted on raw water pump
I need to replace my mechanical fuel pump that is located on my raw water pump (GEN V). Will the Holley mechanical fuel pump (HLY-712-454-11) bolt directly on with no mods or problems. Thanks.
jdub is offline
Old 03-26-2007 | 08:16 AM
I was told that the mechanical arm on the pump is different. When I changed my pumps I bought the Keith Eickert pumps, and they worked really well. You use the top half of your existing pump and put the new lower half on. It gave me the bigger line fittings and larger volume I needed for my upgrades. If you are looking for more volume this is a good unit. Mine is a Gen V also.
GS42fun is offline
Old 03-26-2007 | 08:31 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Gen 5 or Gen 6 fuel pump, increases your fuel system to an estimated 120 GPH mechanical self-regulated from 6-8 PSI. This pump has a -10 inlet and a -8 outlet.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 03-26-2007 | 12:58 PM
DRIPPINWETII's Avatar
Has any one replaced their mech fuel pump with an Electric on this set up? Can you just use a block off plate where it mounts to the Sea pump?
DRIPPINWETII is offline
Old 03-26-2007 | 01:34 PM
Electric is just one more thing to break. They make big enough mech pumps.
jeff1000man is offline
Old 03-26-2007 | 03:20 PM
razor1115's Avatar
I used a gasket and block-off plate when I went to electric fuel pump...
razor1115 is offline
Old 03-26-2007 | 04:25 PM
Nordicflame's Avatar
Yes, it will work but not a direct bolt on.
You simply swap out the diaphram assembly by removing the 6 screws (maybe 8; it's been a while) and reuse the armature assembly. You can also rotate it to what ever suits your needs.
Dave
Nordicflame is offline
Old 03-26-2007 | 05:06 PM
Thanks guys.
jdub is offline
BillR
11
07-29-2022 06:31 AM
BillR
27
08-10-2008 11:31 PM
boatman22
9
01-01-2008 06:00 AM
BillR
4
02-06-2007 03:23 PM
Cignificant
8
07-09-2003 06:21 PM
