Any hull failures on Velocity's?
I know there have been several hull failures on the smaller Velocity's but have there ever been any hull failures on the bigger boats? (41/39)
Hey Chippin it,23 posts and you know so much.NOT.You should not comment when you know nothing in which you speak of.Velocity as far as I know has not had hull failures on the larger 39 and 41 foot hulls but they still have had some of the transom issues with getting water in them so if you are buying one just check the transon and as long as it is solid you will be OK.
