Ignition alarm help. >
Old 03-27-2007 | 08:36 PM
Default Ignition alarm help.
Port side sounds off as soon as you turn the ignition on and it seems worse when its warm. Gauges all look good and fluids have all been checked, what else? Some think it could be just not working right or have a short. It will also not stop once started but does stop after a minute or less. Starboard enging has never sounded.
MOERON is offline
Old 03-27-2007 | 09:32 PM
Moeron,
Hows the new Formula coming? Still finding out things every time you get on the boat? Did you check the drive fluid bottle? Your alarm will sound if the fluid level is low.
Treads is offline
Old 03-28-2007 | 07:02 AM
Originally Posted by Treads
Moeron,
Yea that was checked, I might have someone look at it next week.
MOERON is offline
Old 03-28-2007 | 07:03 AM
Moeron,
Treads,
Thanks for the tip on the color white it matches great.
MOERON is offline
Old 03-28-2007 | 06:16 PM
troc's Avatar
brown wires are used to sound alarms, low drive oil,trans temp,engine temp low oil press.etc when brown wire is grounded it completes audible circuit after a timer counts down{ i dont use timer, when key is turned on alarm sound immediatley until oil press is up then goes off assuming no hi temps] Lift brown wire at each devise until alarm quits. then asses situation . Should be easy to find
troc is offline
Old 03-31-2007 | 08:25 PM
monstaaa's Avatar
actually its a tan with a blue tracer that is the alarm triger wire. as mentioned oil, temp or low drive oil will triger an alarm. sometimes the drive oil is full but the alrm mechanism is faulty.
simply unplug or disconnect each tan with blue tracer wire from said connectors or senders and you should find the problem easily.
monstaaa is offline
Old 04-01-2007 | 03:50 AM
Do what monstaa said. Disconnect the wires from each sensor one at a time and turn the key. When the alarm doesn't go off, you have found the bad sensor. I'm guessing it is a sensor since it does shut off after a minute. If it was a short in the wiring, it would most likely come on intermittently.
Griff is offline
Wodster69
06-24-2008 06:48 AM
MOERON
03-28-2007 01:48 PM
RutRow
2
09-12-2004 05:39 PM
Fast Forward
4
08-22-2004 09:13 PM
waden54
12
06-06-2002 10:12 PM
