Do drive showers slow you down? >
Old 03-29-2007 | 10:31 PM
Default Do drive showers slow you down?
I put on the two pickup halo type and I swear it cost me performance, or am I just nuts?
unbroken is offline
Old 03-29-2007 | 10:38 PM
Ted G's Avatar
I think it might have taken a mile or two off the top end. Only way to tell for sure would be to take em off and run it. Some of that speed may have been lost to the ethanol too.
www.cbpba.com
Ted G is offline
Old 03-30-2007 | 04:14 AM
Check how deep the pickups extend below the plate. I had a problem with prop slip while coming on plane with this shower until I placed a plastic washer under the roll pin to shim the height up a bit. Problem went away once it was shimmed such that the holes were flush with the bottom of the cav plate.
Tim T.
BadDog is offline
Old 03-30-2007 | 08:23 AM
Knot 4 Me's Avatar
I installed a Simrek halo shower and lost no top end...not that I had a lot of top end in the first place!
Knot 4 Me is offline
Old 03-30-2007 | 08:38 AM
Thanks Guys, I'll try that. I definetly noticed a decrease in performance out of the hole. WIll it hurt to remove them and leave the holes open in the cav plate?
unbroken is offline
Old 03-30-2007 | 08:36 PM
SeaRay Jim's Avatar
Check how far they stick down. If you can, shim them up flush to test them. There should be enough flex to do that. I've got a Halo also.
I can't see coming on plane really being affected much since where you'd expect a problem would be where they are sticking down far enough to disturb the water just enough to cause aeration that might increase slip. I'd think that would be at speed.
SeaRay Jim is offline
Old 03-30-2007 | 10:53 PM
nuts
JJONES is offline
Old 03-31-2007 | 12:28 AM
Very good possibility!
unbroken is offline
Old 03-31-2007 | 12:37 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
do a back to back test and let us know your findings. I installed one on my previous boat and thought the prop was blowing out in turns. Never noticed that before. Installed them on my current boat before it hit water, so no idea if I lost anything.
US1 Fountain is offline
Old 03-31-2007 | 01:55 AM
Mr Gadgets's Avatar
Charter Member #601
You could put some masking tape over the holes to try it out.. It wouldnt stay there forever, but may stay long enough to find out if there is a problem.
Any time you disturb the water infront of the prop.. it has an effect..
Mr Gadgets is offline
