Can you restore old gas?
Old 04-03-2007 | 01:36 PM
dyno's Avatar
Charter Member #655
Default Can you restore old gas?
The gas in my boat is 18 months old,it has stable in it is it usable? Will PRI fuel additive help? or should I get rid of it?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-03-2007 | 03:02 PM
NJgr8ful's Avatar
I'd say depending what motors and compression your running, and the octane you 'need' to run, but I heard it drops an octane point or 2 every couple months while it sits.
Personally, I'd dump it start over. Last year dumped @175-200gals Didn't want to chance my new blower motors with 'old' fuel and that was only 5mo. old. Cost me $500 and sucked, but better than melting something and having engine builder tell me "I told you to dump it"
NJgr8ful is offline
Old 04-03-2007 | 03:35 PM
sakoutis3's Avatar
Sell it to a landscaper they can burn it in their lawn mowers.
sakoutis3 is offline
Old 04-03-2007 | 04:10 PM
The answer to your question is NO
burtandnancy is offline
Old 04-03-2007 | 04:29 PM
CMG's Avatar
CMG
run it in your car / truck - for gods sake don't dump it.
Chris G.
CMG is offline
Old 04-03-2007 | 04:42 PM
Mark's Avatar
Thats "liquid gold" these days! As long as you added another batch of stabilizer in it after 12 months, it should be ok. But if you are going to use it, it would be a good idea to add more stabilizer to it first. I believe stabilizer ultimately includes an octane bost. Or, as stated above, sell it to a landscaper, etc.
I have had Diesel sit for that long with stabilizer in it and it worked just fine. Just my .02
Mark is offline
Old 04-03-2007 | 04:45 PM
cuda's Avatar
Retard the timing a little, then add some Toulene to it.
cuda is offline
Old 04-03-2007 | 06:34 PM
Audiofn's Avatar
Charter Member #232
There is no way I would run hard with it that old. Run it REAL easy tell you can get new gas in it then run it harder and harder pregressivly.
Put your best foot forward!
Audiofn is offline
Old 04-03-2007 | 07:32 PM
Linster's Avatar
Off the Radar
Add some premium and move on
Linster is offline
Old 04-03-2007 | 08:41 PM
Check its flammability with a lighter if it goes, its good!
Jupiter Sunsation is offline
