replacing 454 with a 496,will it >
Old 04-03-2007 | 06:45 PM
Default replacing 454 with a 496,will it
Replacing my 454 with a 496 mag,has anyone done this? I am told the 496 is a little bit wider,can I use my old Y-Pipe,are the engine mounts the same location as the 454 on the boat,or do I have to drill new ones,Thanks
apexer is offline
Old 04-03-2007 | 07:36 PM
Linster's Avatar
Off the Radar
Turn your motor into a 496 and save $
Linster is offline
Old 04-04-2007 | 07:53 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
He may be right. It may be less to do yours into a 496.. Also yes the 496 is a little fatter than the 454/502's.. AS far as the Y pipe I dont remember if they are the same or not.. You can compare them on my parts look up on our site.. Jamie
www.LakesideRestorations.com
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 04-04-2007 | 08:07 AM
The 454 motor mounts will work provided you don't have the offshore type. The placement of the mounts is the same but the offshore types have a cradle that will not clear the larger oil pan on the 496.
The exhaust risers are spaced slightly wider by about a half inch. PITA. I had thru hull and a Y pipe with captains choice selectors. The Y-pipe and captains choice had to go and a block off had to be fabricated. I connected to the thru hull using flexible couplers and a section of polished tubing. This allowed me to slightly toe in the exhaust to mate with the old tips. This was better than cutting new holes thru the transom.
The electrical harness needs to be lengthened since the 496 connection is on the back of the engine. The connector is the same.
Great upgrade. The 496 is sweet motor compared to the 454. No regrets.
You should add an additional in-line fuel filter.
NightHawk is offline
Old 04-04-2007 | 11:45 AM
Dave M's Avatar
Veteran: Navy
I replaced my 454 with a 496. I run my exhaust straight back with rubber hose. No problems there. The 496 is a few inches taller. My boat has a low profile and it BARELY fit height wise. I DIDN'T have the wire harness issue that nighthawk mentioned. It was a pretty easy swap.
Dave M is offline
BigErk
7
09-09-2008 08:34 AM
Reckless32
Sunsation
0
06-04-2008 10:31 PM
schurgervt
20
01-20-2008 08:47 AM
DURANGOKID59
11
08-09-2006 06:51 AM
