overheating problems >
Old 04-04-2007 | 09:26 AM
Default overheating problems
I have a 98 genIV 454 merc. boat was used exclusively in salt water. I bought it knowing that it overheated in the higher RPMs. I replaced the seawater and engine water pumps. The boat pumps water out the exhaust. I tried a water test and upon runnning at higer rpms the overheating alarm want off and I shut it down. It sounded like the oil was popping and crackling although the actual engine was not that hot. I noticed the oil pressure dropped from an idle pressure of 80 to around 20psi upon shut down. I am looking for any thoughts on this matter.
drjgt350 is offline
Old 04-04-2007 | 09:34 AM
PatriYacht's Avatar
Have you checked the thermostat?
PatriYacht is offline
fandango's Avatar
From: Solomons Island, MD, Vero Beach and Punta Gorda, FL
Give us a little more information like type of boat, drives, external exhaust or thru drive. Are your risers hot (should be able to put your hands on them without burning them)??
fandango is offline
Old 04-04-2007 | 11:12 AM
hunster's Avatar
How do the spark plugs look? Running lean? Oil temp real hot?
hunster is offline
Old 04-04-2007 | 12:32 PM
Knot 4 Me's Avatar
Could have reduced water outflow through the exhaust due to corroded/partially plugged water jackets in the manifolds/risers.
Knot 4 Me is offline
Old 04-04-2007 | 02:59 PM
My guess would be salt or corrosion build up in the water passages or maybe the oil cooler.
Griff is offline
271fountain
Fountain
14
07-30-2008 10:36 PM
bigpauliehb15
Drives and Lower Units
2
06-18-2007 12:02 PM
bigpauliehb15
1
05-27-2007 09:19 PM
jharran
Pantera
3
05-18-2004 11:21 AM
bowtie89
07-29-2003 07:30 PM
