kooleraire??
has anyone ever tried one of these things. in sits inside a cooler and blows the cold air from the ice in the cooler into a room. i was wondering if it would work in my cabin.
Can you please post a link..... Great idea if it really works. I imagine it works like those coolers you see sometimes at the bar - they put a lot of tubing inside a cooler - probobly about fifty yards. The beer goes in warm and comes out cold.
I bet if you had a small cooler with dry ice it would last all weekend without having to refill with ice.
Sounds like a good cheap business idea.......
I wonder if it can be done on a larger scale like for a house. Probobly have a problem with the amount of air you can get to circulate. This concept is used in geothermal heating/cooling were they run lots of piping underground near your house. The air circulates through the pipes and uses the natural coolness of the ground and then goes back into your house. Not really feasible for TX heat but it is done in other areas. The initial cost is very high but the amount you save on energy pays for itself in 10 years (so the website says).
Im going to check on of those portable a/c units out ---- Tv ad LoL http://www.kooleraire.com/KoolerAire_AD.wmv
http://www.kooleraire.com/kooleraire25.htm
