new 44 Liquid Technologies >
Old 04-05-2007 | 04:01 PM
jhiguy377's Avatar
Default new 44 Liquid Technologies
I had the opportunity yesterday to be with the group while they were testing the 44 all aluminum stepped v-hull. The finish on the boat is amazing in its perfection; my very picky brother was there and he gave the hull finish and execution a 10. The rigging is also top notch; I spent a fair while eyeballing the engine room and systems while getting specifics from the engine builder. They are still working on resetting the x dimension as the drives are still a bit low even with the spacer blocks off of the Teague lowers. They will also change props and gear ratios to get more bow lift. The boat ran 96-97 mph and in my opinion has an awful lot more speed left in it judging by the ride attitude, wetted surface and fairly low rpms. It was a pleasure talking to the owner,the boat builder and their whole team. I enjoyed meeting Tres Martin as well, very knowledgeable and has a few stories from the "good old days". Tim at Oregon Custom Marine is also a wealth of knowledge especially for a "young fella". -Jeff
jhiguy377 is offline
Old 04-05-2007 | 04:09 PM
Strip Poker 388's Avatar
Rob
looks good I wonder what power it has ,looks like tall decks ,must be big cubes
Strip Poker 388 is offline
Old 04-05-2007 | 04:22 PM
Thumbs up Nice to see it.
Looks good guys. Sounds like things are coming together..
Thanks, Cam-shaft.
Cam-shaft is offline
Old 04-05-2007 | 04:49 PM
jhiguy377's Avatar
Default Liquid Technologies pix
here's one more from yesterday -Jeff
Old 04-05-2007 | 05:04 PM
thisistank's Avatar
Dayum that thing is nice!! It even looks better than the first. Congrats! Can't wait to see it in Havasu in a few weeks.
thisistank is offline
Old 04-05-2007 | 05:49 PM
DollaBill's Avatar
OSO OG
850 HP and it ran 97??????????? Am I reading this wrong?
With 1700 HP I can get my Hummer to 97 on water.
DollaBill is offline
Old 04-05-2007 | 06:06 PM
jhiguy377's Avatar
I'm not the authority, just an observer but the destroked 572's(565 cid) are making closer to 700 hp and the boat is not close to dialed in yet. Different props, gear ratio, x-dimension, c/g rearward adjustment, etc and I'm thinking 115+ mph.- Jeff
Old 04-06-2007 | 06:45 AM
CigDaze's Avatar
Looks great guys. Keep up the good work and keep us posted. Sharp looking ride.
CigDaze is offline
Old 04-06-2007 | 01:56 PM
thisistank's Avatar
A Hummer still wont go 97!
I'm not the authority either but have followed both builds on two diffent boating sites. They are still working everything out from what I've heard. This is a completely new boat from the other and they are still faaaaar from dialing it in.
I do believe the old hull went between the 100 and 105 mark with less power and they moved things around on this hull to get it to run more effecient/effectively at higher speeds. I'm guessing 115+ is what they are looking for...and what they'll see when they're done.
Old 04-06-2007 | 03:37 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
The first boat ran well over 115.
This boat will go after they get some different propellers and adjustments.
Rik is offline
