who would you use for prop work >
Old 04-08-2007 | 04:05 PM
nocigarette's Avatar
Default who would you use for prop work
I have had a number of people recomend bblades to me for prop work.........
I am running about 700-730 hoarse 540 na through a speedmaster #3 i am now using a 3 blade cleaver.....The numbers on the prop are mod 1 152x25.....vo22.......whs 684.......which does not tell me anything because i dont know a whole lot about propellers......i run a rpm of about 5700 at 78.2 mph....The boat is a 27 mag with a fairly deep x ......I will measure that as soon as i get the outdrive back on.....any info would be helpfull
nocigarette is offline
Old 04-08-2007 | 05:00 PM
Downtown42's Avatar
bblades or throttle up. Call them both and see whats up.
Downtown42 is offline
Old 04-09-2007 | 08:06 AM
offshoredrillin's Avatar
bblades, no question about it
offshoredrillin is offline
Old 04-09-2007 | 09:51 AM
BURNSMAZZ's Avatar
Thumbs up
Bblades just did a couple Bravo 1's for me, and they look great.Brett was a very friendly and informative guy.I would definitley recommend them.
BURNSMAZZ is offline
Old 04-10-2007 | 04:49 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Thanks guys.
mod 1 would most likely be a race class or even a ref. to a ajustment the propeller went through at one time.
152x25 are measurement notations. I think we have a 25 pitch propeller with a diameter in the 15-15.5" range.
VO22 is most likely a prop shop stamping from some time ago. (I'm not sure on this one.)
whs684 is a date code from the late 80's. The letters should be capitals though.
You actually running pretty well if you have a 1.5:1 gear ratio. 13% slip isn't bad for that boat. I'm sure a face lift to the prop could help though.
Brett
[email protected]
bbladesprops is offline
rssteiny
Prop Talk
3
04-30-2008 08:49 PM
Fast Forward
Prop Talk
18
07-16-2006 09:53 PM
BajaBennett
Prop Talk
5
05-23-2006 05:15 PM
JMPH
2
05-26-2005 05:12 PM
KBUSH1
1
04-01-2004 10:18 AM
