Why starter solenoid and slave (relay) solenoid? >
Old 04-12-2007 | 10:24 PM
Default Why starter solenoid and slave (relay) solenoid?
Finishing up the wiring on my engine and was wondering why you need 2 starter solenoids. Can I start the motor with just the one mounted on the starter?
jdub is offline
Old 04-12-2007 | 10:31 PM
bowtie's Avatar
The slave solenoid lets you run 16 guage wire from the key switch to the engine.
bowtie is offline
Old 04-12-2007 | 10:40 PM
If all my wires are 16 gauge from key switch to engine do I need the slave?
jdub is offline
Old 04-13-2007 | 05:44 AM
Pwrbt33's Avatar
Yes you need the slave. The slave solenoid is the switching point from low voltage wire to high voltage wire.
John S.
Pwrbt33 is offline
Old 04-13-2007 | 06:23 AM
Audiofn's Avatar
Charter Member #232
You need a lot of current to toss the starter relay. The one that triggers the starter relay needs less current to trigger it. You would need almost 8ga wire up to your dash to get rid of the second relay, then you would just have issues with your key switch burning out all the time.
Jon
Put your best foot forward!
Audiofn is offline
Old 04-13-2007 | 06:35 AM
OK, so the 16 gauge wire from the harness goes to the slave then from the slave use 10 gauge to the starter?
jdub is offline
Old 04-13-2007 | 06:40 AM
U got it...
29scarab is offline
Aero654
11
09-08-2021 06:58 PM
US1 Fountain
10
02-20-2008 10:07 PM
86formula242ls
07-12-2006 11:43 AM
Jerry B
5
06-14-2006 08:31 PM
seahawk
12
04-29-2004 02:21 AM
