Composite or bronze disributor gear? >
Old 04-15-2007 | 01:54 PM
Default Composite or bronze disributor gear?
Whats better for billet steel cam? Anybody using the comp cams composite? Also anybody know the size of thunderbolt IV distributor shaft? Thanks.
jdub is offline
Old 04-15-2007 | 02:17 PM
Don't know about about the composite gear, have always used the bronze. Anyway, the thunderbolt distributor has a .491 shaft, same as a GM distributor. Most, if not all, of the aftermarket distributors use a
.500 shaft. Eddie
Young Performance is offline
Old 04-15-2007 | 02:24 PM
Thanks. How often do you change your bronze?
jdub is offline
Old 04-15-2007 | 02:38 PM
I change them every year, at the beginning on the season. It is cheap insurance.
Old 04-16-2007 | 11:27 AM
Default gear
I Have Run The Comp. Gear For 2 Years Had No Problems Yet
dennis r is offline
Old 04-16-2007 | 12:09 PM
Being that the bronze gears are a wear item that often need replaced, Crane says 2K street miles and once per season in marine. I would not want that bronze in my oil so the $100 Comp gear seems a bargain.
Ryan00TJ is offline
Boater8987
Drives and Lower Units
3
05-20-2008 10:29 PM
jdub
13
05-09-2007 09:07 PM
US1 Fountain
7
12-10-2006 07:42 PM
Cmoney
6
04-27-2005 03:20 PM
