In hull transducer mount >
Old 04-15-2007 | 06:28 PM
ls1nova's Avatar
Default In hull transducer mount
OK guys, I might have found where the factory installed the transducer in my hull. Mine is currently mounted on the transom because the marina I bought the boat from couldn't get it to read through the hull. The spot I found is pretty much right under the starter. I'll post up a pic of it. Should I try to grind it out some, or just glue it in and see if it works?
This is on a 280, and it is a Hawk Eye depth sounder.
Thanks,
Frank
Attached Thumbnails In hull transducer mount-dsc02356-large-.jpg   In hull transducer mount-dsc02357-large-.jpg
ls1nova is offline
Old 04-15-2007 | 06:52 PM
Because it is a cored hull, you have to use a hole saw and cut through the coring. Then the epoxy the hole and insert the transducer.
Scary isn't it?
Padraig is offline
Old 04-15-2007 | 06:57 PM
ls1nova's Avatar
That's what I'm wondering. Does that spot look like it was done before? I think I'll have to try to grind out in that circle and see what's going on.
Does anyone with a 280 built around 98 have a factory mounted transducer that can verify the location?
ls1nova is offline
Old 04-15-2007 | 08:54 PM
Frank,
My 22 Velocity has through hull and reads just fine. Not sure of the brand.
DKerns is offline
Old 04-15-2007 | 09:11 PM
Mine is a 98. Factory had me install it just about center-line and almost to the front of the engine. Give them a call and someone will walk you through it. Boat is in storage or Iwould e mail you a couple of pics. I can't check yours as I am not a paid member.
Padraig is offline
Old 04-16-2007 | 07:55 AM
More importantly gentleman, Why is your motor out Frank?
I need specs...I refuse to be the back of the pack. Are you gonna force me to blow it. LOL
No really 600..700...800HP, New drive? come on Give
Vicious22 is offline
Old 04-16-2007 | 10:08 AM
ls1nova's Avatar
hmmm, I'm not sure I should devulge the top secret engine build. I am adding A/C though. That should offset any gains made by the extra hp from the AFR's, cam, intake, ect.
ls1nova is offline
Old 04-16-2007 | 10:05 PM
Don't worry vicious you will be ok if I am part of the pack. I should be well behind you guys.
Frank, I would have made a good excuse for pulling the motor!! Good luck with the motor build.
Dwayne
DKerns is offline
Old 04-17-2007 | 05:25 PM
Nova, for some reason I now get the pic and that looks like the spot.
Padraig is offline
Old 04-17-2007 | 05:33 PM
ls1nova's Avatar
Great. Thanks for the info!
Frank
ls1nova is offline
