How many mile can you drive a day >
Old 04-16-2007 | 09:07 PM
mr_velocity's Avatar
Default How many mile can you drive a day
I'm heading out Wed to pick up the new little boat from Idaho and bringing it back to NJ. Realistically how many miles a day can I expect to put in or actual drive hours? I've never done cross country before, longest trip has been about 700 miles. Can I expect to do a 1000 a day?
mr_velocity is offline
Old 04-16-2007 | 09:09 PM
racesdad's Avatar
YOU BETTER BE ABLE TO. OR IT ISNT WORTH THE TRIP
racesdad is offline
AKA NoMoBoatin
I will be doing the same trip i've done a half dozen times.900 miles in 12-13 hrs to Pompano Beach.Its along day.
docmanrich37 is offline
racesdad's Avatar
Get The Guy To Bring It To Greers Ferry This Weekend And Pick It Up There. You Get The Boat And Watch A Race
racesdad is offline
Old 04-16-2007 | 09:21 PM
Done 1300 miles in 22 hours straight through. My buddy helped me out and took a 5-hour shift in the middle of the drive. Was completely bug-eyed at the end. Too much for one day towing a boat. Will never do it again. 800-900 is reasonable, 1000-1100 tops.
cbeastwood is offline
Old 04-16-2007 | 09:28 PM
Biggus's Avatar
I run from Portland Maine to Jacksonville, 1200 miles. fuel stops only. It's a long day. 900 miles is no problem....if your used to it.
Biggus is offline
Old 04-16-2007 | 09:44 PM
Expensive Date's Avatar
Depends on how you fell I did Denver to NJ once in 47 hrs I slept about 10 so 36 hrs of driving.Just drive till you are tired then stop don't push it.Even if you pull over for an hour in a truck stop and sleep for an hour.Word of advice bring a baseball bat a lot of those rest areas are pretty desolate
Expensive Date is offline
marineclean's Avatar
So then you'll be at the OSS Roar this weekend Kurt?
marineclean is offline
I used to do 1,230 miles straight thru from N.J. to Cape Coral Fl. by myself..............as I've gotten older, can't do it anymore
it kicks my a ss. I now usually go to Daytona or Orlando and
call it quits.
If you can bring someone with you, even if they just do a couple of hours it really helps. Getting old sucks.
Mike 35 Fountain is offline
Old 04-16-2007 | 09:47 PM
Eastern Pa to Oklahoma in 21-23 hours. I do better leaving at night personally.
DKerns is offline
