Dead Batteries-Can't Open Engine Hatch >
Old 04-16-2007 | 09:08 PM
Default Dead Batteries-Can't Open Engine Hatch
Just bought a 2001 Eliminator 3000 Eagle XL. The battery switches and batteries are only accessible from the engine compartment. The batteries went dead and the engine hatch will not open to access the batteries. Any suggestions. Thanks!
tomswift is offline
Old 04-16-2007 | 09:12 PM
If it has a shore power hook up and an onboard battery charger ...plug it in ...open sesame!
First Gun is offline
Old 04-16-2007 | 09:13 PM
t500hps's Avatar
21 and 42 footers
or....eat your wheaties!!!
t500hps is offline
Old 04-16-2007 | 09:15 PM
Biggus's Avatar
Take a booster pack and backfeed the system through the purple wire on the ign switch.
Biggus is offline
Old 04-16-2007 | 09:16 PM
carrboy's Avatar
What he said...just lift hard and have someone put a brace under it... it lifts right up
carrboy is offline
Old 04-16-2007 | 09:31 PM
Hook up a charger to a lighter plug(radio shack) and plug in.
Or as Biggus said.
whoya is offline
Old 04-16-2007 | 09:38 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The battery switches are in the engine compartment?????? I guess they expect you to leave the hatch open whenever you switch off the switches. Be kinda hard to close the hatch with no power. Something seems fugged up.
Might also be able to just put 12V to your lift switch.
US1 Fountain is offline
Old 04-16-2007 | 09:53 PM
Got it open. I put the positive side of the battery charger after the fuse protecting that circuit and ran a jumper cable back to the anode on the drive and connected the negative cable of the battery charger to the jumper cable. The upper section of the rear seat velcros to the boat. When you remove the upper section of the starboard side of the seat there is a 8-9" access hole which you can easily reach the switch for that engine. However. it a good reach around the fire extinguishing system to reach the port side shut off. Thanks for the help!
tomswift is offline
Old 04-16-2007 | 10:24 PM
J-Bonz's Avatar
Velcro.......................................... So thats how its done on the left coast. Jus kiddn, I would definately change that around
Jr.
J-Bonz is offline
Old 04-17-2007 | 10:21 AM
I just put 12v to any terminal on the terminal block under the dash and the up switch works.
ActiveFun is offline
