Glue removal
Old 04-21-2007 | 11:57 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Glue removal
Any idea on how to get the glue off that sticks to the boat after you remove stripes or graphics. Thanks JOHN
Fenderjack is offline
Old 04-21-2007 | 12:35 PM
88formula223's Avatar
NO WAKE ENFORCER
i used goo gone, also orange cleaner i cant remember the name but it worked and smelled good
also used a plastic razor blade and a real razor blade just becareful. Wax after you use the cleaners unless you are restriping....EZ-off oven cleaner works great on cars but I don't know what it would do to Gel-coat
Attached Thumbnails Glue removal-images-large-.jpg   Glue removal-awesomeorange.jpg
88formula223 is offline
glassdave's Avatar
Neno the mind boggler
actually if you dont have alot just get that Glue Gone. you can get it at just about any place like walmart or meijers. if you have alot of removing that needs to be done 3M adheasive remover is avaliable at automotive paint supply stores
08 OPA High Points Champion
glassdave is offline
Old 04-21-2007 | 12:48 PM
99fever27's Avatar
Ive heard these work well in a drill.
Motor-Guard Stripe Eliminators
Designed to fit hard-to-reach areas. Removal of stripes, decals, and molding adhesive. Recommended speed: 1500 to 2500 RPM. Maximum safety speed: 4000 RPM.
99fever27 is offline
Old 04-21-2007 | 12:49 PM
99fever27's Avatar
for about $15 can't go wrong.
Old 04-21-2007 | 08:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The wheel won't burn the gel coat? Or at the very least, leave some type of marking?
US1 Fountain is offline
Old 04-22-2007 | 06:25 PM
99fever27's Avatar
I can't speak from experience, I have never used it. But here is a thread where they talk about how it works. I would bet if you spin it too fast it would melt the gel.
http://www.offshoreonly.com/forums/s...ghlight=eraser
Old 04-22-2007 | 07:35 PM
Just bought and used an eraser wheel on mine to remove decals. Takes glue and everything off. Wish it had been around years ago. Definately the route to go.
nashpda is offline
Fenderjack
6
04-22-2007 04:54 AM
MadDuck1
6
04-14-2006 12:27 AM
Codered
7
04-29-2005 08:28 AM
Dave1972
08-14-2002 08:34 AM
Raypanic
12
01-28-2002 11:55 AM
