prop selection help >
prop selection help
prop selection help
Old 04-21-2007 | 01:02 PM
Question prop selection help
Help! I own a 95 31 Scarab. I was forced to repower due to a broken crank. Needless to say I have a lot more power now so I need different props, and in a year or two new outdrives.
Elevation where I boat is 2152 ft, I am running bravo 1 drives (1.5) with twin 540 carbureted motors. I was running 24p bravo 1 4 blades with my stock 502's. I do not want to exceed 5600 RPM. Estimated horse power is 600 to 650 per engine.
Any suggestions on what type of prop and pitch I should start with? This year of boat is heavy so I was thinking 30p. I would also like to have a prop that will work when I upgrade my drives if possible. Thank you.
chuckcrick is offline
Old 04-21-2007 | 01:23 PM
I think 28 Bravo 1's would be a good starting point.
Griff is offline
Old 04-21-2007 | 06:01 PM
I'm guessing the weight of the boat to be around 8000 lbs. It should be able to run high 80's and a 28-30" prop seems like the right choice with 5600 being target rpm. I am basing this on about 1100 total shaft horsepower. I second starting out with the 28. My guesstimates put that boat around 67-70 with the old power. As far as props being upgraded, you should just need the XR hub kit if you are using a Bravo 1 prop. If you use a prop with a fixed hub, you'll probably need new props. I am assuming that by upgrading drives you are talking about going to an xr.
Rene
oldandtired is offline
Old 04-21-2007 | 06:31 PM
gsmith9898's Avatar
I have a set of labbed 28"s
gsmith9898 is offline
Old 04-22-2007 | 09:16 PM
Default Thanks
Thanks for the advice.
I am glad I posted this because my rationale for thinking a 30 pitch was what I needed was because I have a friend with a 38 Scarab AVS with twin 500's carbureted and he is running a 28 pitch. He runs out low 5's for RPM and 72 MPH GPS. I realize his boat is more efficient but I didn't think that much. I am running a minimum 200 hp more then he is and at least 2k less in weight then him. I guess I was looking at it the wrong way.
Thanks everyone.
As far as Labbed 28's; thanks but I am very much a recreation boater and I will probably buy standard props. We have too much junk in our lake and my investment in labbed would not last very long. I am figuring $500 to $600 for the set which is what I will get for my 24's. Again thanks.
Old 04-23-2007 | 06:40 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Hi Chuck,
I recieved the email. I agree with the 28 pitch Bravo 1 as the starting place. Doing the calculations brought me to the 4 additional inches of propeller needed. There may need to be some minor adjustments to the propeller after you run them and get a baseline.
Be careful buying used propellers. Ask questions about the age and any repairs or rework that may have been done.
Brett
[email protected]
bbladesprops is offline
Old 04-23-2007 | 07:35 PM
mboger's Avatar
i think i would be careful with the drives if they will hold help
mboger is offline
Old 04-24-2007 | 07:26 PM
Default Drives
I agree, XR's are on the list. I will have to baby my drives until I get new ones. Pocket book only goes so deep.
Thanks for the post.
Courtholl
Pantera
8
03-31-2007 10:13 AM
speedboatr
Prop Talk
3
08-31-2006 06:22 AM
RACER8
Skater
2
07-21-2004 03:31 PM
RACER8
1
07-19-2004 11:37 AM
phastang
2
04-24-2002 07:46 AM
