Looking For Parts Drake Exhaust
Here is the deal...
water leaks from underneath the exhaust. there are 2 kind of nylon washer for each bolts that goes underneath the manifold part. Just can't find this in my area.
So I went on internet for drake exhaust and beside mustang Drake exhaust, I can't find where is the company from so neither their phone number.
I need at least the washer / gasket. If bolts are available, I'd take some too.
Anyone has any idea where I could find those ?
That entire set up looks like a bunch of leaks just waiting to happen. I would just get 3 T fittings and one 90* that would screw into the bottom of each manifoldand connect them with rubber hose. basically the same as what is on a Gil system.
Either that or get straight fittings to screw in and use a CMI style distribution hose.
Not to mention, get rid of the copper pipe manifold to riser fitting.
