Hydromotive vs Bravo 1 props
Just wonder what the performance difference would be between the Bravo 1 vs the Hydromotive Quad? I tried a Bravo 1 last year and it seemed to give my boat a little to much lift in the stern. Will the hydro do the same?? Years ago I had a Scarab anf the Hydro was by far the fastest prop for the boat. But that was 12 years ago and things have changed.
Hydromotive also makes a Quad IV-X which is more similar to the Bravo (rounded blade tips), and from what I've been told is a more efficient prop. I have a 24" Q IV-X and it runs around 6-7% slip at WOT.
Are running that Q IV-X on your Pantera?
If so, how does it compare to your M+ as far as top speed?
Patrick
Patrick
In stock form it's slower. I'm going to have Todd at Hydromotive lab it for me and see if I can get it closer to the Mirage. The 24 doesn't get over the hump, and turn up like it should. I can only get 5000-5100 out of it. But, I also tried a 22" of the same prop and turned that one almost 6000 at 75 and change.
Unless Rob (Stormrider) had the prop cut into a M+, the Mirage I have is just a regular Mirage. I would like to try/find a 25" Mirage or Mirage + because I think that would prove to be the fastest and still keep the RPM's conservative (My 23 Mirage turns 5800+ @ 78 or so mph)
