Fuel Pressure sender question? >
Old 04-29-2007 | 05:22 PM
2112's Avatar
Question Fuel Pressure sender question?
Of the two plugs on the sender, one is to the guage, is the other a purple ignition wire or a ground wire?
2112 is offline
Old 04-30-2007 | 03:49 AM
I would think the other is the ground.
HighPriority is offline
Old 04-30-2007 | 09:33 AM
2112's Avatar
I thought so too and wired it that way and got to wondering where the juice to power the gauge came from. Guess it has an ignition wire to the gauge it self.
2112 is offline
Old 04-30-2007 | 10:19 AM
tssteph's Avatar
Yes it is the ground. The gauge has it's own power source. Typical gauge will have a neg pos and sender marking.
tssteph is offline
Old 04-30-2007 | 11:43 AM
2112's Avatar
Thanks Guys
2112 is offline
Old 09-10-2007 | 02:50 PM
Rocko C's Avatar
Default Fuel Pressure Sender thread size ??
I'm getting ready to mount my fuel pressure sender also, I'm taking the plug out of the back of the fuel rail. It's a tight fit with the distributor cap right there (2000 502 Mag MPI) but it'll have to do. Any idea as to the thread sizes of the sender and fuel rail ?
Thanks,
Rock
Rocko C is offline
Old 09-11-2007 | 09:10 AM
offthefront's Avatar
Thanks,
Rock
I would think its 1/8 pipe thread ....
offthefront is offline
Old 09-11-2007 | 09:44 AM
Wally's Avatar
Were doomed!
The sending units are basically variable resistors that send different levels of a ground signal to the gauges...which then shows what the reading is.
If you have two spots for wires it most likely one gets a ground wire......or....you may have a dual station unit..meaning it can feed two gauges...seeing that its going to be exposed to fuel..and most likely be using teflon to seal it up it would probably interfere with the ground signal..thus the two wires.
As for the tight fit on the fuel rail...you can always use a 90* fitting or extensions to get it out of the way...
-Wally
Wally is offline
Rage
0
05-13-2008 04:13 PM
JLS
Powerquest
0
08-04-2007 06:05 AM
Grog
2
07-08-2006 01:54 PM
Pure Energy
2
05-13-2006 04:17 PM
Nordicflame
2
04-13-2005 12:35 PM
