Trailer Wiring
Old 05-02-2007 | 07:21 PM
Default Trailer Wiring
anyone have any good trailer wiring diagrams?my wiring needs to be redone
awsomethunder is offline
Old 05-02-2007 | 07:35 PM
BAD ENOUGH's Avatar
Brown is running or clearence and tail lights. Yellow is left turn and stop . Green is right turn and stop . Blue is for elec. trailer brakes . White is ground to trailer and truck. Red if present is aux. power or batt . charge line.
BAD ENOUGH is offline
Old 05-02-2007 | 07:56 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Blue is for reverse lights/reverse solenoid lock out for surge brakes. Electric brakes can vary depending on setup/manufacturer.
Sydwayz is offline
Old 05-02-2007 | 09:15 PM
Wooderson's Avatar
Here's a chart:
Wooderson is offline
Old 05-02-2007 | 09:21 PM
scottc's Avatar
In a 7pin plug, there is 2 blue wires. The larger one is for the electric brake system and the smaller blue wire is the back-up lights.
In any system use a test light to verify the wireing. I have seen way tomany misswired plugs.
If you go to Draw-tite.com you will find the different plugs and how they are wired. If you still need help, I can fax over the info to you.
scottc is offline
Old 05-02-2007 | 09:25 PM
scottc's Avatar
here ya go
http://www.drawtite.com/6and7waywidi.html
scottc is offline
Old 05-02-2007 | 10:20 PM
buck183's Avatar
Black if present should be aux power.
Red if present should be reverse lights.
buck183 is offline
Old 05-03-2007 | 07:35 PM
thanx guys
fastlane40
3
12-20-2006 06:58 PM
JohnJan
13
07-01-2004 06:22 PM
BAD-HABIT
3
06-21-2003 07:43 AM
97BossHammer
04-28-2003 04:03 PM
mpally
05-21-2002 08:53 PM
