Measuring engine height ????????? >
Old 05-03-2007 | 06:54 AM
Default Measuring engine height ?????????
Guys -
Can someone walk me thru measuring engine height? I have a 30 foot Spectre with twin 300 Mercs. I've been told that engine height should be ~ 1 1/2 inches above the bottom of the boat.
Are they referring to prop shaft height? The front of the nosecone? That should be the same thing, right? What's the best way to measure this? Also, are you suppose to measure straight ahead of the nosecone, in a straight line, to the back of the boat? Reason I ask is the boat is "deeper" towards the middle.
Thanks,
Mike Sufka
St. Cloud, MN
mikesufka is offline
Old 05-03-2007 | 12:44 PM
Measure with propshaft parallel to bottom of boat. Tape a ruler to the transom, then use a straight edge to extend where the prop shaft center would meet the ruler. Keep the straight edge at the same angle as the propshaft.
Griff is offline
Old 05-03-2007 | 09:30 PM
monstaaa's Avatar
i have ste up cat outboards in this fasion. straight edge( 4 foot level) directly in front of bullete. as stated measure to center of bullet from top of straight edge. the formula you can start with is , for evey 4 inches you can come up 1/4 of an inch. typicly 1 1/4 - 1 1/2.
you can also differ the heights from left to right, which will make the boat crab, but also make it faster.
monstaaa is offline
Toffen
09-26-2006 05:42 PM
Toffen
Prop Talk
4
03-28-2006 11:51 AM
apache21
Skater
3
09-26-2003 12:30 AM
jonesj
06-12-2003 03:24 AM
Cord
7
03-29-2003 09:13 AM
