Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Trim gauge broken >
Trim gauge broken
Trim gauge broken
Old 05-03-2007 | 12:19 PM
Default Trim gauge broken
I need a wiring diagram for a merc trim sender.Any one have that? I bought a new gauge set but the trim gauge does not work and I thing it just needs some wire help thanks !
scorpion king is offline
Old 05-05-2007 | 05:53 AM
Full Force's Avatar
I am looking for the same thing!
Full Force is offline
Old 05-05-2007 | 11:35 PM
Check your wiring where it runs from the sender in through the transom. If that appears good with no breaks in it, then check the wires from the transom ass'y all the way to the back of the seat area as far as you can. Usually these wires get brittle and corrode or completely break off and that kills the signal. If your wires appear good, pull the gage out of the dash and hook up the sender with a short run of wire directly to the gage and rotate the sender to make sure everything works properly with good wires. If everything works right, go back and check your wiring again, because you probably missed some bad spots somewhere. Believe me, sometimes you can inspect the wires several times and still miss a break in the insulation or wires! 99% of the time there are multiple breaks in the wiring from the sender, and most of the time there are breaks in the gage indicator sender and the trim limit switch both! A "quick" repair to get you back in the water is to use a bit of good quality extension cord to jumper from the senders on the gimbal to wherever your good wiring starts. Just be sure to zip-tie the wires up and out of the way so they don't get caught in the prop or pinched off when you turn, and to solder and shrink wrap where you connect in to the good wiring inside the engine bay for safety's sake. We also tied off to the bottom of the swim platform keeping close to the transom until you can get to a good place to get into the engine bay. It will get you back on the water in a pinch until you can get those wires replaced correctly. Remember, that's only a TEMPORARY fix! Be prepared for a PITA job when you do the replacement job on the wires for real, but it's oh-so-nice when everything's back to working the way it should. If this doesn't help you out, email me [email protected] and I'll see if I can get you more info. Bill
CCstinger260 is offline
86formula242ls
05-23-2007 04:40 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
georges
5
12-01-2004 11:24 AM
temp
09-14-2004 02:56 PM
ChrisK
01-16-2003 04:17 PM
