Electric Trailer Jack AC connection >
Old 05-03-2007 | 08:49 PM
dukenrock's Avatar
Default Electric Trailer Jack AC connection
I installed an electric tongue jack and connected it to the factory trailer plug 20 amp pin (1:00 position on plug) I keep blowing fuses on the tryck breaker if there's any excessive weight being lifted. (If the ball doesn't release right away) If I hook the jack up to a jumper cable it seems to do fine. Do I need to homerun a power line direct from the truck battery to the jack?
dukenrock is offline
Old 05-03-2007 | 09:22 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Sounds like you are pulling too may Amps across that circuit. I think your safest bet is to do as you described.
Sydwayz is offline
Old 05-03-2007 | 09:28 PM
See if the paperwork for the jack shows a max amp load. If you're lucky, it might show something more than 20 and explain blowing the fuse. If you're REALLY lucky it will be under 30 and you can just put a 30amp fuse in (and hopefully not fry the wire).
handfulz28 is offline
Old 05-03-2007 | 09:31 PM
dukenrock's Avatar
Thanks.....I was afraid of that. Spent an hour today trying to get the stupid trailer off the truck by myself while the wife and Daughter were waiting for me at the dock. It should have been a 2 minute deal. Had to pull the truck jack out and it finally came of the ball.
Old 05-03-2007 | 09:33 PM
dukenrock's Avatar
I as thinking of a 30 amp and just keeping my hand on the wire form the jack. There's a slow-blow fuse on the wire to the jack. I'll check the amperage. If not, Sdwayz said he'd run a new wire for me.
Old 05-03-2007 | 11:30 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Kevin, I don't work for cheap. You should see me wire a PBX.
Sydwayz is offline
Old 05-04-2007 | 05:46 AM
scottc's Avatar
You could install a battery on the trailer and wire your 12v source from the truck to that battery. Most ele trailer jacks use the extra battery due to the high amp draw (@25-50) The higher you rase the trailer and increase load, the amps will go up also. If the truck dose not release you will max out the jack. Try to rock the truck once you see it start to load up from lifting the truck.
Good luck.
scottc is offline
Thumpurr
American Offshore
0
09-12-2008 05:10 PM
dukenrock
13
02-16-2007 05:20 AM
pachangalpina
7
09-24-2004 09:00 PM
Dean Ferry
9
12-01-2003 05:16 AM
Magicfloat
04-16-2002 08:46 AM
