Any HP guesses before it goes on the dyno next week?
600cid
Dart Big M tall deck 4.6 bore
Lunati Pro 4.5 stroke crank
Oliver billet 6.7 rods
JE coated dished pistons static 8.7:1
coated bearings
14 qt. pan
Jessel belt drive
Morosso external oil pump
BMF 385 heads with blower CNC program
Jessel pro shaft rockers
Morrel lifters
Blower shop 1471
Blower shop intercooler
Nickerson Stage 5 Dominators 1175cfm each
MSD pro billet distributor
MSD 6M ignition box
CMI Big Tubes with dry tails with o2 sensors in each tail (primaries are 2 and 3/8")
cam specs solid roller
265/269 @.050
lobe lift .4360/.4320
separation 112
timing events @.050 (20.5) (64.5) and (66.5) (22.5)
Duration @ .020 298/304
Gross lift .741/.734
valve lash hot .023/.029
coated bearings
14 qt. pan
Jessel belt drive
Morrel lifters
Blower shop 1471
MSD 6M ignition box
265/269 @.050
separation 112
I woulfd guess 1300-1400hp (with a real correction factor,no bs stuff) if your running 10-12 psi of boost. What drive do you plan on blowing up behind this
,Smitty
,Smitty
Goal is 1000hp on pump gas. Going in a 26' cat with Teague Platinum with 1.36's and 2" shorty and realize I will have to be easy on the drive.
http://media.putfile.com/born2burn-2005
