525 Merc backfiring
Boat ran great all weekend, docked it Saturday night. Sunday morning I took it out, got it planed off no problem. I noticed the Starboard Floscan meter was reading about 20 GPH (I think at 3000 rpm) and the Starboard Floscan was less than 15 GPH (At the same rpm-thought that was odd) then the Starboard motor started backfiring and loosing power. It would idle fine and all gauges looked normal, no alarms. I could put the engine in neutral and get it to backfire just reving it up. Any thoughts?
I'll tell 'ya this fuel now breaks down some rubber and I personally think filter element sitting in the filters for 7 months. Not to mention attracts H2o when it sits.
I'm changing all 4 filters before I start the engines for the season. I have them here.
the program is now change them in the spring for these reasons.
after the stereo install that is.
Kevin,
Your boat sure looked good running Saturday in the poker run. Did you buy any dock gas? I try to stay away from the stuff. Even docks with good intentions and equipment can get water into their lines through condensation, leaks and osmosis.
Nice to meet you and your family.
Regards,
Steve
Regards,
Steve
I fueled up on land before I launched Friday and boat ran great. I refueled on Saturday morning at GH Marina. (90 gallons) That's the fuel I was using during the PR event and it seemed to run OK but that's when I started to notice the Starboard/Port GPH readings were not anywhere close. Could have been the beginning of the problem.
Thanks for the compliment! You had a sweet ride as well. We had a great time and it was nice meeting you too. Have a safe season and hopefully we can hook up again. Maybe I can buy you a drink next time!
Kevin
Kevin
Kevin
Kevin
We're on with the drink for sure
. My friends with the 29' Formula really liked your boat as do I. Sounds like it has a genset and AC? Pretty, fast, and comfortable is the best of all worlds to me.Simply Kevin, I think you got a bad load of gas. That's the only only thing that changed, and your motor began to act up. I would either pump it out, or add a lot of gas dry and change the water separating fuel filters.
Bad dock gas usually is worse this time of year (sitting for some time due to slow sales, loses octane, gets condesation, etc.). This is not very high tech, but I would remove the filter from the backfiring motor (carefully) and empty it into a Mason jar or large clear water glass. If it has water in it, it will seperate out from the gas and be easily visible.
Regards,
Steve
PS, please feel invited to join us for our MCPA poker run here in Nashvegas on Old hickory Lake August 4th........
www.musiccitypowerboat.com
