42 Fountain Gas tanks? >
Old 05-07-2007 | 11:15 PM
tomtbone1993's Avatar
Default 42 Fountain Gas tanks?
I have a 91 triple 42. It has 4 spots to fill up the side tanks and 2 saddle tanks. It has 2 fuel sendors under the rear bench. The 4 years I have owned the boat I have never filled up the back tanks nor the saddle tanks. No need to since I boat on a small lake.
If you have not seen my Ethanol thread in the genral disscusion area I have bad gas.
My question is this. Are the front tanks gravity feed to the rear tanks? "not the saddle tanks"
I pulled both sendors under the bench and both were full.
Thanks, Tom
tomtbone1993 is offline
Old 05-08-2007 | 11:36 AM
monstaaa's Avatar
ther should be a set of levers or rods on the rear fire wall to switch from saddle to main tanks. stainless steel with little round balls on the ends. usually red and black ones.
you may have been running off the saddle tanks this whole time.
you should see them while looking down in front of the engines on the fire wall.
good luck
monstaaa is offline
Old 05-08-2007 | 11:44 AM
good luck
the saddle tanks have always been it the off position.
what about the 4 tanks in the belly?
Old 05-08-2007 | 06:22 PM
monstaaa's Avatar
ther should be a diverter vslve of sorts like the ones for the saddle tanks. this is an uncommon set up for a consumer boat. you sure it has 6 tanks?
if it does typicly the siphon from one to the next
monstaaa is offline
SUNSATION 25
Powerplay
7
08-31-2007 06:58 PM
gripit
Cigarette
20
05-31-2005 01:43 PM
BOB ONEIL
Cigarette
0
11-16-2004 01:25 PM
DBELL6
03-27-2004 08:13 AM
DBELL6
0
03-25-2004 08:58 PM
