Exhaust tips needed
The only kind I ever saw were the standard bolt on tips that the tip goes into the bilge and you connect the hose and clamp to the tip inside the bilge, and the kind that have the flange/pipe separate with the rubber flange gasket. So with your tips, the rubber hose goes thru the transom hole, and then clamps to the pipe? Im sorry man, I dont get it??
