Voltage drop when thru hull exhaust open >
Old 05-09-2007 | 06:27 PM
Default Voltage drop when thru hull exhaust open
I have a 2000 Baja H2X with 454 Mag MPI and Bravo 1 drive, corsa switchable exhaust. Lately when I press the switch to open the exhaust, the voltage drops 2 volts and stays there. I am thinking the relays or solenoids to open them are stuck.... but really not sure. Looking for any information you guys could help with.
Thanks in advance.
RYAN JOHANSEN
H2X BOSS is offline
Old 05-09-2007 | 09:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The solenoids use power to keep them open. They are spring return to the close position. The 2 volt drop seems a little high though.
US1 Fountain is offline
Old 05-09-2007 | 09:50 PM
Mines the same..
ghittner is offline
Old 05-09-2007 | 10:31 PM
tblrklakemo's Avatar
SeaRay Sundancer
I used to have the same. The flaps are indeed spring loaded and shut when the power is off. The draw to keep them open seems a bit high though.
tblrklakemo is offline
Old 05-09-2007 | 10:53 PM
I seem to have just the oppisite problem, when I switch to loud exhaust my alternator jumps up about 2 amps!
05 crown lpx is offline
Old 05-10-2007 | 07:17 AM
The solenoid that Corsa uses pulls 30A to move, .75A to hold. It has an internal switch. If the travel does not permit the operating rod to reach the bottom, it will stay at 30 amps. Check it.
BROWNIE is offline
Old 05-10-2007 | 03:08 PM
troc's Avatar
where are you getting the power to operate the solenoids? a distrobution block near the gauge panel, you might have better luck if you control them through a relay close to the batts, similar to a trim pump. It might not be an actual 2 volts, just pulling current through small gauge wires shared by gauge power/grounds.
troc is offline
Old 05-12-2007 | 09:46 AM
thanks for the help so far, hopefully have some time to tinker on Sunday... It wasn't always like this, but it is enough of a power drop to turn off accessories like the radio sometimes... hmmm
H2X BOSS is offline
boomer
3
07-18-2006 12:07 PM
Reckless32
2
05-19-2006 05:16 PM
thegreygoose
1
05-12-2004 02:32 PM
Innov500s
2
05-17-2003 08:11 AM
Dr. Fred
9
05-23-2002 12:53 PM
