remove/clean fuel fitler seadoo gtx >
Old 05-10-2007 | 03:38 PM
Default remove/clean fuel fitler seadoo gtx
does anyone know how to remove and clean the fuel filter on a seadoo bombadier gtx? 1996
tweco is offline
Old 05-10-2007 | 03:41 PM
Wally's Avatar
Were doomed!
If memory serves me right i think its a fuel/water-filter/sepperater all in one....you lift the front hood and take out the bin/tray....behind it under the steering should be a bulb that you unscrew and clean out.....thats it i think...i dont think theres an actuall fuel filter like you would find on a boat/car...but i could be wrong..its been a while since ive seen or worked on one
-Wally
Wally is offline
Old 05-10-2007 | 03:48 PM
Ted G's Avatar
Wally's memory is good, mine needs cleanup 2-3 times a season.
www.cbpba.com
Ted G is offline
Old 05-10-2007 | 05:51 PM
heres the skinny on older seadoos, as they get older the gas actually degrades the inside of the fuel lines, gunking up the filter, carbs etc.. replace all the fuel lines with good stuff, new filter and go over the carbs..your toubles should then be over for a looonnngggg time.
phragle is offline
Old 05-11-2007 | 08:44 AM
thanks for you help i found the filter and took it apart.. do i clean it out with compressed air?
tweco is offline
Old 05-11-2007 | 09:20 AM
Ted G's Avatar
Better to spray it down with carb cleaner and let air dry. If you use comp air you can split the screen if you're not careful.
www.cbpba.com
Ted G is offline
Old 05-30-2007 | 08:23 PM
FYI... There is a tiny little fuel filt in the pump side of the carb. Follow the pulse line and take the cover off. 4 screws hold it on. Very easy to clean...
teamsynergy is offline
tweco
06-10-2007 09:32 PM
tweco
15
05-30-2007 08:26 PM
betitbig
4
09-07-2006 08:14 AM
jeff32
01-02-2006 08:52 PM
