Compound when detailing boat >
Old 05-11-2007 | 06:46 PM
35 White Lightning's Avatar
Registered User
Default Compound when detailing boat
What type of rubbing/ polishing compound to bring back the shine on a 95 35 all white, I was thinking about using finesse it first with a wool pad, then using a Mequires fiberglass wax
35 White Lightning is offline
Old 05-11-2007 | 07:14 PM
The 3M Finesse It is an excellent product. Try using a waffle foam finishing pad, they work well and do not throw as much material off as a wool pad. Your compound will go farther, just remember to use a slower speed. Then use the wool pad to do the final pass to really bring out the shine. Good Luck.
RaggedEdge is offline
Old 05-12-2007 | 07:48 AM
Registered User
thanks for the tip I will use it
Old 05-12-2007 | 04:01 PM
monstaaa's Avatar
FINESE IT IS REALLY A GLAZING COMPOUND. micro fine compound will remove a lil bit more material than the finese it, if thats necessary. garys satin wax, or even better marine clean wax for a finish like no other.
just keep in mind that the more you remove the faster it will oxidise and fade .
unless of course its clear were speaking about.
monstaaa is offline
Old 05-12-2007 | 07:43 PM
35 fountain's Avatar
I just spoke to Donnie at Marine Clean - He has an oxidation remover that is marketed through trick marine. I dont have any personal experiance yet but he seems to really know his stuff.
35 fountain is offline
Old 05-13-2007 | 07:33 AM
He was asking about compounds, my reference was to the Finesse It Micro Fine polishing compound. I believe it is rated as a 3000 grit product. IMO none better. Needs to be followed up with a quality wax / finish product for a lasting shine. Most of the oxidation removal products I've seen simply feed oils / silicones into the finish to cover the haze of minor oxidation rather than cutting it away, and therefore do not give a long lasting finish. I've used the 3M Micro Fine for years and IMO it does a better job than any other product I've tried.
Old 05-13-2007 | 09:38 AM
monstaaa's Avatar
3000 grit will nmot remove scratches or stains. it is a great product, i agree. donnies products work very well. i use them on all my customers boats and on the fountains i have in my showroom, and on the trade in's. even my car, and it works great, applies easily and lasts.
the oxisdation remover works nice.
if you need to go a little more agresive, than i would use the micro from 3m with a foam pad as stated.
monstaaa is offline
Old 05-13-2007 | 10:33 AM
Strip Poker 388's Avatar
Rob
This ? Will it leave swirl marks?
Strip Poker 388 is offline
Old 05-13-2007 | 12:32 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
We are also a distributor for Donnie's products.. & yes his stuff works extremely well..
As far as super faded units wet sand first if needed. Then use 3m superduty compound or gel compound first & then work you way up with finesse it & leverage for the ultimate gloss & protection...
If it is lightly oxidized then The Leverage/marine clean oxidation remover followed up with Leverage is an excellent way to go..
If ya need any feel free to call me.. Jamie / lakeside 570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 05-13-2007 | 02:09 PM
monstaaa's Avatar
slight, but hen you finish up with the finese it or similiar product and then marine clean.
monstaaa is offline
