BAZOOKA Tube ?
Old 05-12-2007 | 08:48 PM
speed demon's Avatar
Default BAZOOKA Tube ?
Does any one have any experience with using a Bazooka Tube sub woofer in their boat? Any pro's or con's? Do they sound pretty good or not? This is the one I am considering. The black automotive ones are a little cheaper. I suspect the white which is stated marine may have very minimal differences. I am thinking it would fit perfectly in one of my side storage areas where I store fenders now. Thanks for the advice!
Bazooka MBTA10200
Marine Certified 10" High-Power Amplified Bass Tube
Product Description:
Patented Bass Tubes enclosure design
Water resistant enclosure
Weather resistant velcro reinforced mounting straps
Salt fog and UV certified for 5 years
White paint finish
Gold plated 5-way binding posts
Power Handling: 200 watts
Sensitivity: 104 dB
Frequency Response: 39 Hz - 250 Hz
Magnet Size: 28 oz.
Dimensions: 21.1"L x 10.3"W x 12.2"H
1-year Sonic Electronix warranty
Subwoofer Specifications:
Subwoofer Size: 10"
Impedance: 4 ohms
Dual Voice Coil: N/A
Peak Power Handling: 400 watts
RMS Power Handling: 200 watts
Woofer Surround: N/A
Woofer Composition: N/A
Sealed Box Volume: N/A
Ported Box Volume: N/A
Sensitivity: 104 dB
Xmax (millimeters): N/A
Top Mount Depth: N/A
Cutout Diameter: N/A
Warranty: 1-year Sonic Electronix
speed demon is offline
Old 05-13-2007 | 08:20 AM
I used the Black Bazookas tubes on mine and they sound much bettter then I thought they would with good thump!
I couldn't bring myself to cutting any holes for subs so I went the tube route and am very happy with the results. No issues being non-marine after 2 seasons!
Attached Thumbnails BAZOOKA Tube ?-sub-amp-side.jpg   BAZOOKA Tube ?-p4170162.jpg
ZP'd is offline
Old 05-13-2007 | 08:48 AM
BillR's Avatar
OSO Moderator
If you want hard rap type thump at very loud volumes look elsewhere. Bazookas work quite well for some really decent bass.
Recommended!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-13-2007 | 09:34 AM
monstaaa's Avatar
put four of em in and pump the thump
just make sure you keep a screwdriver handy to tighten all the screws that are gonna loosen up,,,,,,,,,,
monstaaa is offline
Old 05-13-2007 | 10:42 AM
if there crossed over correctly and some good juice is pumped to them they will hit hard
tomcei is offline
Old 05-13-2007 | 07:53 PM
Thanks for the feedback.
ZP'd - It looks like you went with the Bazooka Tube with out the integrated Amp.
Any one with a recommendation with or with out amp?
I'm thinking of getting one with the 200 watt built in amp. Then will use a JL Audio 4x75w amp to power 4 Alpine 6.5 speakers. Nothing crazy just want clean sound with some bass.
Old 05-13-2007 | 10:30 PM
88formula223's Avatar
NO WAKE ENFORCER
If I where buying I'd get the external amp, more control and if you want to up grade you can use it for something else also the marine isn't worth the extra $$ unless you want white
http://www.etailelectronics.com/Merc...ore_Code=etail
I did 2 8" subs in mine in the same type of location as you want to use and it sounds great just make sure you give them enough clean power, I would of done 10's if I had it to do over so now Im trying to find a place for these 12"s I have laying around
I would go with truck style boxes and 2 10" inch subs
boxes bottom depth is less than the tube
http://www.crutchfield.com/S-sximaF6...0&I=044T6510SS
10s
http://www.crutchfield.com/S-sximaF6...FFSize%7C10%22
I recommend these and JL I have both and they are worth the money
these are the 8's I have they are the Mclass
http://www.memphiscaraudio.com/
88formula223 is offline
Old 05-14-2007 | 08:06 AM
Gladhe8er's Avatar
I have the 10" amplified marine Bazooka tube and it hits decent. I was actually expecting a bit more though, but that could be because I had 2 15" subs in my truck in high school.
Gladhe8er is offline
Old 05-14-2007 | 11:03 AM
I wanted the ability to have a bit more control, thus the 8ohm tubes bridged off the Alpine 220 amp.
The only goal of my system I had was to be able to hear it well at speed with a little thump and they more then do that.
ZP'd is offline
Old 05-15-2007 | 09:58 PM
Andy Buzz's Avatar
My shop is factory direct with Bazooka and we stock many models of Bazooka tubes. Call Mike or I when you are ready to order and we will get you a deal.
Maximum Audio
Tampa,FL
813-882-8477
Andy Buzz is offline
aTX427
4
03-17-2004 10:06 AM
ccarloss
08-23-2003 06:35 PM
kaamacat
5
07-26-2003 10:51 PM
HyperBaja
05-20-2003 09:27 PM
Shooter
7
05-31-2002 06:42 PM
