Tach Sender
Old 05-13-2007 | 07:51 PM
gripit's Avatar
Default Tach Sender
Where does the tach sender wire attach to on the motor? The motor is a 420 hp. Thanks
gripit is offline
Old 05-13-2007 | 08:23 PM
monstaaa's Avatar
there should be a grey tach lead in the harness under the dash. if not use the grey wire on the coil.
monstaaa is offline
Old 05-13-2007 | 08:39 PM
gripit's Avatar
Are you saying the sender wire runs to the ingition coil?
gripit is offline
Old 05-13-2007 | 09:34 PM
Yep, tach gets its signal from the neg side of the coil.
Griff is offline
SCARAB98
Wanted
1
05-31-2008 04:37 PM
SCARAB98
Scarab
1
05-30-2008 10:17 PM
SCARAB98
2
08-20-2007 03:34 PM
Danny_Ocean
4
04-05-2004 10:47 PM
thespy
1
05-21-2002 11:00 AM
