500 EFI Spark Plugs >
500 EFI Spark Plugs
500 EFI Spark Plugs
Old 05-15-2007 | 07:37 AM
Default 500 EFI Spark Plugs
What is the best spark plug to use for the 500EFI? Also what should the gap be for the plug?
Thanks,
Mike
Mikey Likes It is offline
Old 05-15-2007 | 09:10 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
NGK BPR8ES is what is called for in the manual. The gap is stamped on top of the motor.
Sydwayz is offline
Old 05-15-2007 | 01:05 PM
Strip Poker 388's Avatar
Rob
also MR43t standard AC marine plugs. the NGK will be cheaper
Strip Poker 388 is offline
Old 05-15-2007 | 02:27 PM
I Use The Extended Tip R43TS - Gap Should Be .035
Donzi38ZXXX is offline
Old 05-15-2007 | 03:19 PM
Rob
I run the AC42ts in my 500efi whipple motor. The 43 or the #6 should be good
Spark plug cross referance
http://www.dragstuff.com/techarticle...reference.html
Old 05-15-2007 | 03:20 PM
What do the extended tips get you? Are there any draw backs to using the extended tips?
Old 05-15-2007 | 03:21 PM
Rob
some good info on this site
http://www.dragstuff.com/techarticle...-pictures.html
http://www.dragstuff.com/phpBB2/viewtopic.php?t=22
http://www.dragstuff.com/techarticle...ead-plugs.html
hpscarab22
2
05-19-2005 05:12 PM
sleeker
5
04-15-2004 06:42 AM
John B
2
09-13-2003 08:33 PM
Rick G
5
09-05-2003 07:11 PM
SLINGSHOT
06-12-2002 03:45 PM
