06 6.0 turbo coking
Old 05-15-2007 | 10:19 PM
Default 06 6.0 turbo coking
Dealer said my turbo was coked. I had intermittent no boost. when it would boost it had good power. Engine light would light when towing but soon go out. It seems to me that if it were coked it would have no power or boost all the time. Any suggestions?
382 newbie is offline
Old 05-15-2007 | 10:26 PM
JCPERF's Avatar
Coked as in a kilo or cooked?
JCPERF is offline
Old 05-16-2007 | 12:43 PM
Wobble's Avatar
SORE MEMBER
Have a look around http://forums.thedieselstop.com/ubbt...003Drivetrain1
You should find a solution there
Wobble is offline
Old 05-16-2007 | 01:16 PM
Are they going to warranty it?
Wannabe
wannabe is offline
Old 05-16-2007 | 05:37 PM
Yes no problem, I went to the dealer today to see my cab 10' in the air and stuff scattered everywhere, sheez. The mech showed me the turbo. There is a sliding section that varies the boost. That section hangs up and needs to be cleaned and polished. They told me they see it more in engines that idle alot. I usually warm up my truck 5 min or more, they said not to warm up more that a few. OK, most of the turbos that they clean and polish do not come back. We shall see.........
Old 05-16-2007 | 05:45 PM
stecz20's Avatar
i cooked a turbo in my 6.0.. after that i had 0 issues... think i had 15,000 on it when it went.....
stecz20 is offline
Old 05-17-2007 | 08:55 AM
Coked and cooked are two different events. Coked is where the oil has broken down and crystallized due to excessive heat, common association would be failing to idle down after towing. Cooking is basically smoking the unit completely.
Tim@DOA is offline
Old 05-18-2007 | 07:56 AM
BillR's Avatar
OSO Moderator
Try Hotshot.
It is supposed to cure the 6.0 oil issues:
http://www.lubricationspecialties.com/
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
berns29scarab
03-27-2008 10:59 AM
bblythe
12-07-2007 11:18 PM
littledcsrodshop
12
08-07-2006 10:18 AM
cmikeplay
Nordic
0
04-15-2005 07:10 AM
