Exhaust setup >
Exhaust setup
Exhaust setup
Old 05-20-2007 | 12:19 PM
Default Exhaust setup
Last summer I installed these manifolds and tails. The tails are 4.5" diameter. I was running 4" tips. What I did was cut a piece of 4" exhaust hose, slide it onto the tip flange, then used 4.5" hose to connect the tails to the tips. Heres the problem, the hoses burned up in a couple hours becuase the angle is to sharp from the end of the tails to the tips.
I am thinking of going with a pair of those transom rings, that will allow some slack for the angle. Also, instead of running 10 inches of hose to the tips, just use a longer 4.5" pipe and get within a inch or so from the rear of the tails and use a rubber coupler. I didnt like having to reduce the size down from 4.5" to 4". The water dumps into the exhaust stream right at the end of the tails. Any thoughts? Who make transom rings that fit 4.5" pipe? Thanks!
MILD THUNDER is offline
Old 05-20-2007 | 12:21 PM
Plus I would like the tips to be longer.
Old 05-20-2007 | 12:22 PM
pic
Old 05-20-2007 | 12:57 PM
betitbig's Avatar
I have 4 1/2" exhaust and needed some new custom tips made.
Eddie Marine made them to my exact specifications and I had them in about a week.
Call JC over there and he will hook you up...
betitbig is offline
Old 05-20-2007 | 09:59 PM
are those manifolds for a bravo on a boat w/ trannys?
sschafee01@snet.net is offline
Old 05-20-2007 | 10:13 PM
No, they were designed for the 420HP 454 trs
Old 05-20-2007 | 10:35 PM
Hmmmm, I'm runnin' harder angles with no problems, are you sure you're runnin' enough water there???
ghittner is offline
TwinTurboStroker
1
09-30-2006 10:38 PM
mkulikow
0
04-26-2006 11:21 AM
PWRCAT
7
05-13-2005 02:57 AM
redfountain420s
03-25-2005 08:26 PM
