38 Fever setup >
38 Fever setup
38 Fever setup
Old 05-20-2007 | 09:00 PM
Default 38 Fever setup
I have a '99 38 Fever with 700 blower motors. Last year I ran the boat with stock Bravos at 90 mph turning 29 pitch Mirage 3-blades. At the end of last season, I broke a Bravo so I am swapping -2 Imco's. Has anyone tried shorty's on an older twin step hull like this? What happened? I am planning on running a Bravo 4 blade or maybe seeing if Throttle-up recommends a five-blade. Any advice is appreciated.
nealmobile is offline
Old 05-20-2007 | 11:48 PM
Rebel_Heart's Avatar
I just installed -2 Imco shorties on my single step 2001 35'. Just in the break in period now on the new drives. I'm using a Bravo 1 now and it planes easily. I won't know on top speed for several weeks and I have it labbed.
Rebel_Heart is offline
Old 05-21-2007 | 01:14 AM
Registered User
Hi Rebel Heart,
I am very interested to hear the results on the new Imco's shorties. I have the same boat and have thought about the same mod. What gear ratio's and prop pitchs are you using, and what did you have before? I have Bravo drives with 1.5 gears and was told that Imco shorties would give more speed.
TIA
David
Dkahnjob is offline
Old 05-21-2007 | 06:20 AM
Is a '97 35 a single step or a twin. does it have a notched transom
Old 05-21-2007 | 07:15 AM
I run a set of 26p Hydro Quad 4s on my 99 38 Fev. 500 hps. Boat runs north of 80. You definately need 4 blades. I think there is a guy on here running shorties and 5 blades though with super results.
RAF
runafever is offline
Old 05-22-2007 | 12:08 AM
I would love to here from the guy running shorties and five blades. setup is still a mystery at this point. this weekend i'm trying a pair of 30 bravos. i'll be thrilled if i can get on plane.
Old 05-22-2007 | 10:43 AM
That would be me. Here's the thread you want to check out.
http://www.offshoreonly.com/forums/s...ghlight=picked
So far the best prop for my boat has been a Hydromotive PX-5blade.
But if you are running bravo's instead of XR's then you could easily start busting drives with 5 blades and that much hp.
Marginmn is offline
Old 05-22-2007 | 10:53 AM
ohh, and be sure to watch your water pressure when you test it - mine was off the charts when I went to the -2 imco's - so much that I blew a hose off and had to install pressure relief valves to get it down.
Marginmn is offline
Old 05-22-2007 | 06:27 PM
monstaaa's Avatar
this is a 99 with naturally aspirated 750's, 2" shorty lowers on 1:50 XR's. boat used to run around 103 104 with tricked out 14 1/8 x 32 4 bld mercury props. it ran a solid 100 with worked 5 bld maximus wheels. much better cruise and planeing time with the max's, just sacrificed top end a lil.
the engines turned around 5800 6000
monstaaa is offline
Old 05-22-2007 | 07:33 PM
Bo knows Fountains
Marginmn is offline
