Water pressure
Guys,
Where are the water pressure sensors located on a 500hp? Are they sensors or just ports that use pressure to drive the gauge (like a boudon tube)? My port water pressure gauge quit registering after we got stuck in mud Saturday. I assume its just plugged but need to know where to start backflushing.
Zack
Zack
Usually, water psi gauges are manual and should be tied into one of the engine block drain plugs.. That way you are getting exact block psi. I am going to say you have a hose coming off the stbd side of the block in front of the starter just above where the oil pans starts. Thank you, Cam-shaft.
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
