496 Stroker - Stock fuel pump or larger? >
Old 05-24-2007 | 01:48 AM
Craig B's Avatar
Default 496 Stroker - Stock fuel pump or larger?
A Gen IV 496 stroker, 850 Demon carb on a Dart intake with Lightning headers.
Do I use my existing seawater/fuel pump setup, or do I go electric or other?
Thanks in advance
Craig B is offline
Old 05-24-2007 | 05:58 AM
Pwrbt33's Avatar
The stock pump would probably just make it. You can buy different bodys and leave the pump mounted on the sea pump. Carter, holley and some others all make interchangable pumps. Then you can raise the pressure and change the fittings to braided if desired.
John
Here is an example from Summit Racing. You can take the pump body off the top and put it on yours. Just 6 screws and there ya go!
Pwrbt33 is offline
Old 05-24-2007 | 06:15 AM
I have the same setup. I have a Edelbrock pump and it runs solild at 7.5 PSI.
1BIGJIM is offline
Old 05-24-2007 | 11:50 PM
How many GPH, BIGJIM ??
Kidnova is offline
Old 05-25-2007 | 06:20 AM
I would have to look it up, I bought it from CP Performance.
Just a guess as I am getting old 110 GPH
1BIGJIM is offline
Old 05-25-2007 | 05:02 PM
kaama82's Avatar
Be careful, your on the edge. I was running stock pumps on my 496 with Holley 830's. Everything was good. I switched to the Holley 950 HP series, Then I didn't have enough fuel. I changed my pumps to the Holley black, I think there rated at 140gph. Everything is good now.
kaama82 is offline
Old 05-25-2007 | 05:55 PM
BY U BOY's Avatar
get a 130gph pump and regulator
BY U BOY is offline
Old 05-25-2007 | 08:46 PM
kaama82's Avatar
I forgot to mention, I did use a regulator.
kaama82 is offline
Old 05-25-2007 | 11:40 PM
Craig B's Avatar
Thanks guys - you're the best.
Craig B is offline
253checkmate
2
12-24-2007 01:44 PM
Craig B
6
05-29-2007 06:12 AM
BY U BOY
04-10-2007 10:46 AM
techman
2
05-22-2006 12:14 PM
StrikinLightnin
45
09-05-2002 08:57 AM
