stock fuel pump on a 7.4l
Is this the belt driven or cam driven pump? either way they need an upgrade if you go much over stock hp, cpperformance sells a new valve body that will up output to the 110gph rate for the belt driven one, for cam driven you can find plenty of upgrade pumps off the shelf.
Is this the belt driven or crank driven pump? either way they need an upgrade if you go much over stock hp, cpperformance sells a new valve body that will up output to the 110gph rate for the belt driven one, for crank driven you can find plenty of upgrade pumps off the shelf.
BillR
11
07-29-2022 06:31 AM
Rage
6
07-31-2007 09:45 AM
