Can u use regular car rims for a trailer >
Old 05-25-2007 | 08:44 AM
Wild's Avatar
Default Can u use regular car rims for a trailer
Just got this 20 and i am going to paint the trailer silver so it looks like aluminium, and wanted to put some cool rims on it, like some 20" chrome rims, will this work, what about the berring
Attached Thumbnails Can u use regular car rims for a trailer-img_1182-large-.jpg
Wild is offline
Old 05-25-2007 | 09:20 AM
mopower's Avatar
Toxic FORMULA
The boat is light enough , weight should not be a problem. I did it myself with a 21'r. Used 15" Ford LTD aluminum wheels out of a junk year for $140 for all four. Ran it seven years , including a trip to Florida (from Jersey). I don't think I'd used 20s though
mopower is offline
Old 05-25-2007 | 10:18 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I think you will probably be better off with "the Myco Trailer Wheel" that they had exclusivity on for a long time, or the Pacer Outlaw II which is also 3000 lb. rated clear coated aluminum. I definitely like the CRC race boat's trailer, and the like; but I just would not trust such setup for the privateer for the long haul.
The wheel that Myco made popular:
http://www.championtrailers.com/rims.html
Sydwayz is offline
Old 05-25-2007 | 10:44 AM
tblrklakemo's Avatar
SeaRay Sundancer
I saw a sweet rig a couple yrs ago. Chevy silverado towing a color matched trailer and boat....truck and trailer rolling on matched corvette rims.
tblrklakemo is offline
Old 05-25-2007 | 10:51 AM
Wild's Avatar
i have seen magazines with trailers that have 20s on them. may be hot boat or something like that
Wild is offline
Old 05-25-2007 | 10:57 AM
czy40p's Avatar
We have these on a horse trailer, and I will probably buy set for the boat, Stainless steel=no worries.
Jim
czy40p is offline
Old 05-25-2007 | 12:01 PM
ZBODaytona's Avatar
i would check the load rating other than that bolt it up. I ran my stock dodge wheels on a trailer i had for years. Though they were truck wheels.
ZBODaytona is offline
Old 05-25-2007 | 01:35 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Its not so much the rims I'd worry about. As long as you find the right wheel with the right weight rating, you are good. However, the taller you get in rim, the wider you get in rim, and then you are going to get into width clearance issues.
I run LT E-rated truck tires on my dually AND my boat trailer. EVERY time I stop when towing, I use the Laser Pyrometer (Temp Gun) to check the temp of each truck and trailer tire sidewall, each truck and trailer tire tread, each hub assembly on the trailer, each trailer brake disc, andeach trailer brake caliper.
I know the acceptable ranges for my setup based on uniformity. My trailer tires normally run 100-125 degrees on the sidewall (slightly warmer on side toward sun), and 125-150 degrees on the tread.
My concern is that a wider tire is going to generate more heat, and also not dissipate that heat as well as a narrow and more traditional trailer type setup. When you go to that 20" or taller rim, you are putting the rim in more peril closer to the road, debris, and curbs, and are drastically decreasing the amount of sidewall; which also now has less surface area to dissipate heat.
Sydwayz is offline
z.zuperboat
Superboat
5
03-23-2007 08:39 PM
slpcamaross97
7
09-14-2006 07:55 AM
Hot Boat
05-21-2006 12:57 PM
Ca$hed Out
04-16-2006 10:41 AM
26ZX Donzi
06-03-2003 07:11 AM
