Julie Throttle up >
Julie Throttle up
Julie Throttle up
Old 05-26-2007 | 06:17 PM
Default Julie Throttle up
Julie
I just tested my 25p lab finished prop from you. I also just installed the new dana flow torque exhaust. Im running 67MPH GPS @ 4800 rpm . Do I have anything left. Its a 23 outlaw with a 496 mag and bravo 1 1.5 drive.
pol98xc6 is offline
Old 05-28-2007 | 04:36 PM
throttleup's Avatar
I will pull your info tomorrow and take a look.
Julie
throttleup is offline
Old 05-30-2007 | 01:24 PM
Julie did you forget about me?
pol98xc6 is offline
Old 05-30-2007 | 03:13 PM
Can I ask
What RPMs and GPS before having the prop labbed?
1BIGJIM is offline
Old 05-30-2007 | 05:42 PM
throttleup's Avatar
Call me at the lab tomorrow, 727-531-2255 and we can go over things.
Julie
Old 05-30-2007 | 06:15 PM
Originally Posted by 1BIGJIM
Can I ask
Before I was turning 4700 and 64.6MPH GPS
pol98xc6 is offline
Old 05-30-2007 | 07:29 PM
throttleup's Avatar
Very Nice! A 3MPH increase is very good for a Baja, or should I say any conventional Deep Vee hull. Your motor needs to run at 4800 zRPM at WOT so you have arrived. Congrats!
Julie
Old 05-30-2007 | 08:56 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I don't want to throw a fly in the ointment but, you picked up 2.4 mph and 100 rpm with two adjustments. Exhaust and what ever prop work was done.
My point is, do one change or upgrade at a time. It is difficult to determine what worked and what didn't do much.
I'm surprised the exhaust didn't give you more rpm on its own.
You can actually run those motors right to the 4950 limiter without anything but performance gains.
[email protected]
bbladesprops is offline
Old 05-31-2007 | 07:58 AM
I added the dmp exhaust and went from a 23p non lab finished mercury mirage+ to a 25p lab finished mirage.
pol98xc6 is offline
Carder
Prop Talk
1
06-04-2007 08:49 PM
TxFountain
Prop Talk
0
09-03-2006 06:38 PM
Sydwayz
Prop Talk
5
08-30-2006 03:29 PM
Cigaretteman
Prop Talk
2
07-31-2006 12:44 AM
OldSchool
04-01-2005 06:18 PM
