What would cause this? >
Old 05-27-2007 | 06:58 PM
Default What would cause this?
My neighbour has a small Donzi, 25 or 28.
single 454 injected
When he brings it up to about 1200 rpm the motor just quits.
Makes an air suction sound and just quits.
If you start bringing up the rpm and right at the 1200 rpm mark spray some starter/either then it goes past the 1200 and runs fine.
Does this in gear and in nutral.
Midnight__Express is offline
Old 05-27-2007 | 07:00 PM
This boat is about 1 year old.
Old 05-27-2007 | 08:45 PM
[QUOTE=Midnight__Express;2142086] spray some starter/either /QUOTE]
Cant help you with what sounds like a fuel injection problem but ..... the only place for the starting spray is in the trash can .... that stuff is the best way to kill an engine. If you insist on using something, use Gumout or 2+2 carb cleaner. It will accomplish the same thing without hurting anything.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 05-27-2007 | 08:50 PM
Thanks, I'll let him know.
Old 05-27-2007 | 08:53 PM
Sounds like you sucking air in from somewhere. Check around the intake and plentum by useing the spray. You could even use WD40.
Noise Pollution is offline
Old 05-27-2007 | 09:12 PM
Thanks,
that is what I was kind-of thinking..then once it build up enough vacume it sealed itself, like a cracked vacume hose or something.
We're still looking.
Old 05-27-2007 | 09:47 PM
Dave_N's Avatar
First thing you need to do is check the fuel pressure. Are you sure it is a 454? If the boat is on year old it would have a 350 Mag or maybe a 496, but not a 454.
Dave
Dave_N is offline
Old 05-27-2007 | 10:01 PM
Positive on the 454, not positive on the year, but it's fairly new.
Fuel presure is good. It's something else?
Old 05-27-2007 | 10:08 PM
Originally Posted by Dave_N
Newport Beach...
Dave
I miss that Place. So much stuff to do there.
Did avalon survive the fire there?
Old 05-28-2007 | 01:36 PM
boatn70's Avatar
BillK-
whats the story behind starting spray....what does it actually do to the motor?
excuse my ignorance.....
b70
boatn70 is offline
