oil filter blew the gasket out
Ok so I took the boat out to check my fuel pressure I got on plain when I got to 4,000 rpm I smeld oil I looked back and it was all over the gasket on the top of the filter blew out.It is a Fram racing filter on a Dan olson cooler. What do you guys think?Is there a better filter with not so thick gasket. Thanks
Raymo,
What type of oil pressure do you have ? As much as people dont like Fram filters, I have never seen a problem with the Fram Racing ones, only with the cheap stock ones used in high oil pressure situations or with blocked bypass valves. Wix also makes a nice performance filter if you want to try a different brand.
Make sure there is not two gaskets on the filter, a lot of times the gasket from the old filter will stick to the housing when you remove it and if you put the new filter on with both gaskets, they will almost always leak or blow out.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
Ray,
If your oil pressure is not excessive, and the mounting surface on the cooler is ok, really any good filter should work ok without blowing the gasket out. I have been using the Wix racing filters lately due to availability, but have used plenty of the Fram Racing ones too and have never had a problem. The Wix and the Fram both seem to have about the same thickness gasket as all of the rest.
Is this a new setup ? Is it possible there is a restriction of some type in the oil cooler lines ?
Oil filter study.
http://minimopar.knizefamily.net/oilfilterstudy.html
Short verson
http://minimopar.knizefamily.net/oilfilters.html
Short verson
JGB
21
02-08-2011 11:24 AM
