Question - I haven't run my engine in almost 2 yrs >
Old 05-29-2007 | 09:00 AM
Phantom1's Avatar
Default Question - I haven't run my engine in almost 2 yrs
Aside from getting rid of the old fuel, what other things should I check out or watch closely once I get new gas and batteries in?
It is a 540 with dual carbs.
Yeah, yeah, I know - if I used it more, I wouldn't be asking this question.
Thanks-
Attached Thumbnails Question - I haven't run my engine in almost 2 yrs-mvc-012f.jpg
Phantom1 is offline
Old 05-29-2007 | 11:12 AM
BY U BOY's Avatar
Make sure pistons are not seized by cranking over by hand. go thru the carbs and check to make sure the oil pump is priming. Also replace the raw water pump.
BY U BOY is offline
Old 05-29-2007 | 11:35 AM
Replace raw water impeller. Pull the spark plugs & spray some fogging oil in each cyl & turn over by hand. Reinstall plugs & disconnect coil. Use starter to turn over & build oil pressure. This is the procedure I use each spring. After running it for a few mins replace the fuel filters.
benztech is offline
Old 05-29-2007 | 03:02 PM
Fresh oil, and maby let the fogging oil
sit in the cylinders a few days before spinning the engine over.
johnny b good is offline
Old 05-30-2007 | 03:59 AM
cig1988's Avatar
You'll have it running by next week ?
cig1988 is offline
Old 05-30-2007 | 08:39 AM
Panther's Avatar
Frank's Marine Service
How big is the cam?? May wanna test valve spring seat/open pressures to be sure the open ones aren't weak.
Panther is offline
Old 05-30-2007 | 08:45 AM
Phantom1's Avatar
I seriously doubt it..................
Phantom1 is offline
Old 05-30-2007 | 11:37 AM
Registered User
I would squirt a little marvel mystery oil in the cylinders and let it sit.
320es is offline
Old 05-31-2007 | 04:00 AM
cig1988's Avatar
Been hustling my azz off for the road trip myself. Everything I touch turns into a can of worms. Went to rotate & balance tires on the dually...sidewalls were dry rotted. Converted to elec/hyd & was servicing the wheel brg's yesterday..have to replace every single brg & possible a spindle. I still have not got my boat wet.
cig1988 is offline
chuckbeecher
02-01-2009 02:31 PM
stecz20
Sonic
25
12-25-2008 11:58 AM
ChiToWn TapouT
01-26-2006 09:12 PM
Flat Deck
03-03-2002 09:16 PM
