i have twins and both rotate right >
Old 05-29-2007 | 07:00 PM
Default i have twins and both rotate right
i have an 86 27ft machone with twin 350s. both props are right hand rotation. speed is around 60 at 4500. is this normal or would i benefit from counter rotating props? and should i change the port lower unit to turn left? thanks for any help you can give!
craig pogue is offline
Old 05-29-2007 | 07:23 PM
PhantomChaos's Avatar
Have you had the boat out? I would imagine that it is quicker to turn one way or the other.......?
PhantomChaos is offline
Welcome to OSO!!!!!!!!!!!
Old 05-29-2007 | 07:56 PM
I had a 28 Cigarette that was like that. I always wanted to convert it to counter rotation but never did. I don't know if I would have gained any speed, I don't think so. I think it would have helped slow speed / docking handling.
Hi Nort!
BajaFresh is offline
Old 05-29-2007 | 08:01 PM
Turbojack's Avatar
what kind of outdrives? Bravos?
Turbojack is offline
Old 05-29-2007 | 08:03 PM
counter rotating outdrives did not come out untill bravos came out in the 90's.
PurpleStuff is offline
Old 05-30-2007 | 07:09 AM
"i have twins and both rotate right"
When I first saw this I thought your were bragging that your boys wern't queer
ciaoderhead is offline
Old 05-30-2007 | 07:18 AM
cuda's Avatar
1986, so I'm guessing they were Alpha's. I had a Formula 242 LS with twin 350's and right handed Alpha's. The best money I spent on that boat was a tie bar between the drives. They do make a counter rotating alpha drive.
cuda is offline
Old 05-30-2007 | 07:34 AM
I had a 90 29' Searay with twins and counter rotating alpha drive. They turned out. One engine was also left hand rotation which was common back then.
Steet is offline
Old 05-30-2007 | 07:38 AM
Clay Washington's Avatar
My advice... Keep the boat "as is". Use it, love it, and eventually sell it.
You're gonna go bigger in a couple of years anyway!
Welcome to OSO!
Clay Washington is offline
