496 HO oil drain tube problem. >
Old 05-30-2007 | 10:01 AM
tblrklakemo's Avatar
SeaRay Sundancer
Default 496 HO oil drain tube problem.
I have the factory EZ oil change tube that runs from the drain pan on my HO, and out the bildge drain hole. I dont think the previous owners ever used the tube b/c they had a dip stick sucker. I cannot get the screw in end on the tube off. Can I cut it off and attach a new drain screw? What would you guys use that will still fit through the transom hole?
tblrklakemo is offline
Old 05-30-2007 | 11:03 AM
Dave M's Avatar
Veteran: Navy
I have one of those rubber type drain plugs. So, the hose fits through.
Did you try using 2 wrenches to get the fitting off? You have to hold the tube end with 1 wrench and unscrew the the fitting with the other. I can't just unscrew the fitting without holding it with another wrench
Dave M is offline
Old 05-30-2007 | 11:14 AM
SeaRay Sundancer
Yeah i did.....the sucker is on there real tight. I almost rounded the corners off completely. I think I will just order myself a whole new kit for $50. The current rubber tube i have has seen better days. Just curious how easy it is to install a new tube with the motor in the boat?
Old 05-30-2007 | 11:45 AM
Bill 3's Avatar
You can borrow my oil change bucket (sucker) if you want.
Bill 3 is offline
Old 05-30-2007 | 11:50 AM
SeaRay Sundancer
Hey Bill, have a fun weekend? Good to meet you and yours. I will probably just hold off another week on the engine oil and do the drive this weekend. You going to be on the water this saturday?
Old 05-31-2007 | 09:40 AM
Bill 3's Avatar
It was great meeting you also. Other than getting caught in the rain every day, we had a great weekend. We should be out on Saturday.
Let me know if you change your mind on the oil change bucket. You are welcome to bring your stuff by my dock and get the oil changed right there. Not much of a job with the bucket.
Bill
Bill 3 is offline
Old 05-31-2007 | 12:50 PM
Dave M's Avatar
Veteran: Navy
LOL! My boat has REAL good access to the motor and it's still tough. I tried to install a tube on my old 454 still in the boat and gave up.
Dave M is offline
Old 06-01-2007 | 11:36 AM
It was a very easy job on my 454.
Ken
minxguy is offline
davis777
8
06-20-2011 09:39 AM
teaguecustommarine
New Products and Member Discounts
1
02-28-2007 03:31 PM
teaguecustommarine
8
10-06-2006 10:28 AM
hammer_34
10-12-2005 12:53 PM
Blade38
1
05-12-2003 09:12 PM
