Best way to setup stereo system and batteries? >
Old 05-30-2007 | 12:52 PM
Default Best way to setup stereo system and batteries?
Ive got two batteries, one for each motor. Seems like I end up running the battery down pretty fast with the amp and stereo on while hanging out in the coves.
Whats the best way to setup a 500w Directive Amp and Sony Xplod head unit so that I dont have to worry about the motors startin up when I head out.
I have an onboard battery charger with shore power but would like to get a full weekend out of the batterys without having to recharge. The stereo voltage drops way out on hard beats, should I put a capacitator in to help it recover?
How do you guys have yours set up?
waterboy222 is offline
Old 05-30-2007 | 02:00 PM
Wally's Avatar
Were doomed!
A full weekend without recharging??? not gonna happen if you run the system hard.....i had 4 batts on my scarab.....each motor had its own dedicated battery...the main electrical system had its own battery and the stereo had its own battery......i had 4 switches for it all and could switch to any combination of batteries if need be. Most times i ran the stereo till it starts cutting out then switch to one of the engine batts...once that one was going low i would either turn it way down or start the engines up and let it run for a while to charge back up....i never had any problems with not having cranking juice for the engines at the end of the day.
-Wally
Wally is offline
Old 05-30-2007 | 10:04 PM
I was going to try something similar to this. I want to have one batt for house (gauges, lights, etc), one batt to start both engines, and then a bank of batts (2+) for amps. I'm wiring everything from scratch though so it's a little easier for me.
http://www.amplepower.com/primer/pwrsys/index.html
jackhammer is offline
Old 05-31-2007 | 08:34 AM
Wally's Avatar
Were doomed!
The only problem i see with that setup as shown is both alternators are wired together....the voltage regulators will be fighting each other...i'm not sure what that "Smart next step regulator" is though....
-Wally
Wally is offline
Old 05-31-2007 | 07:12 PM
I just talked to Bob at Amplepower... he said, first of all, the drawing is outdated. There is a new regulator I should use called SARV3 along with their dual alt controller. ~$575 total package.
He also said I needed externally regulated alternators.
zimm17
6
07-13-2006 01:16 AM
pshannon
04-24-2006 06:51 AM
pshannon
04-11-2006 01:22 PM
magnum27
2
08-12-2005 08:22 AM
MiamiVice
11-30-2004 07:08 AM
