fuel pump/sea water pump >
Old 06-03-2007 | 07:02 AM
fastedy's Avatar
Default fuel pump/sea water pump
Any one know what the flow rate of the Fuel pump that
monuts on the sea water pump on the Gen 5 blocks, will it
support 650 to 700 hp. I would like to get rid of my electric fuel pump and crank driven water pump and go to a more simpler system, What would be my best set from tank to dominator carb and also supply water to the engine. I am running a water pump bypass.
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 06-03-2007 | 07:20 AM
I wanna say flow rate is 120 at 7. But you can adapt any fuel pump you want to the sea pump by just using the base (arm) of the old fuel pump bolted to a new fuel pump.
jdub is offline
Old 06-03-2007 | 07:26 AM
Check out www.racepump.com
cobra marty is offline
Old 06-04-2007 | 09:51 AM
Has anyone here used the mech. CV fuel pump, that bolts onto the Merc sea pump ??
Kidnova is offline
Old 06-04-2007 | 09:17 PM
The CV pump bolts on the Merc seawater pump. It is expensive, but will feed 700hp easily. It is also rebuildable. They put the correct fuel pump arm on their Nascar billet pumps.
PPlay33 is offline
Old 06-05-2007 | 06:18 AM
fastedy's Avatar
What is CV pump, how do i find them?
thanks, Eddie
Mario Andretti
fastedy is offline
Old 06-05-2007 | 10:18 PM
rbtnt's Avatar
I have run CV pumps for 6 years on my 625 HP enignes. They work great. I did replace the gaskets once when they upgraded them.
Here's a link.
http://www.cvproducts.com/cv/
www.mtboats.com - Pages of boat related links
rbtnt is offline
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
HP500Hammer
15
01-30-2008 06:03 PM
Bryan Rose
4
12-29-2006 06:59 AM
David Haag
4
05-04-2004 08:32 PM
